Thread: brake issues
    Mar 2005
    Parma. Oh-sub of Cleveland
    472
    brake issues
    Hey all, well this weekend i went home and rode my 350x, but its got problems. well first, the brake level got real soft, like nothing there, and the front cailper is sticking.. .So i filled the cylinder up and see no leak, and the level still is weak, and the cailper is still sticking, i can ride it, but when i do a wheelie the tire stops spinnging. and my rotor gets hott, now, the two problems dont go together, if the cailper sticks then the level should be rock hard, but its not. why is it doing this? thanks.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
    1985 Polaris Indy 500
    1986 Polaris Indy 400 liquid-For Sale
    1988 GMC sierra 1500
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Sounds like you need to take the caliper off and at least check the slide pins. If they are sticking it will cause the pad to rub on the rotor. Another thing is the caliper pistons. If they are sticking, it will cause the same thing. As far as the soft lever, it sounds like you need to bleed the brakes.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    thebutelr's Avatar
    thebutelr is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Golconda, Illinios
    160
    Quote Originally Posted by IrvSLedman
    I had this exact same problem with my X's front caliper and fixed it with a rebuild kit. Your pistons are most likely gummed up causing them to pop out but not slide back in. I'd take the pistons out, clean them, and replace the seals. Remember to install them with fresh brake fluid.
    Mar 2005
    472
    alright, thanks for the tips, Ill try that this weekend.
    1985 350x
    1985 Tri-Z
    1983 200
    Atc 70
    1985 200s
    -parts for sale
