Results 1 to 8 of 8
Thread: Fourtrax rear linkage to an ATC 250R?
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    I just got done buttoning up the rear suspension linkage om my 86 R. I ended up using some my old stuff, because I could not get some of it new, But it's still in good shape yet. Parts are getting hard to find.
    Just wondering if anyone has used the Fourtrax 250R stuff on their trike, either the whole works, or in part, if any of it will work.
    That would make things better down the road when it comes time to replace again, if the FourTrax stuff will work..
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    May 2005
    Australia
    1,047
    I have an '89 TRX swingarm,rear brakes and lowering strut(Durablue) all fitted to my 85 250r with no problem.
    Aussieduner
    Keeping 3 Wheelers Alive Downunder !
    Oregon
    2,471
    Quote - I have an '89 TRX swingarm,rear brakes and lowering strut(Durablue) all fitted to my 85 250r with no problem.
    Aussieduner
    Can you post a picture of that set up Aussieduner ?
    Jun 2003
    englishtown NJ
    2,676
    I have 86 trx stuff on my atc's. It all works, just remember the bottom shock linkege bolt(that ties it all together) is a larger diameter on 86 atc/trx and up.
    May 2005
    Australia
    1,047
    Quote Originally Posted by ceaserthethird
    Aussieduner
    Here you go,its an 85 frame with 89 swinger fitted its all pretty easy to do.
    Aussie
    InPiEcEs's Avatar
    Apr 2004
    Northeast Wisconsin
    378
    Quote Originally Posted by deathman53
    So that is the only difference in the linkages?
    In that case all a guy would need is the linkage and that bigger bolt to use it on an ATC.
    Then all the linkage kits for the FourTrax would work, I assume.
    In switching to the later model 88-89 swinger,, you would need the linkage to swinger bolt as well, right?
    I just want to know for when the time comes that the 85-86 linkage parts are no longer available, so I have options to keep the beast going
    1995 CBR600F3
    Jun 2003
    englishtown NJ
    2,676
    for a 88/89 swinger switch, you will need a back motor mount welded in, and also the 88/89 swinger is 1" shorter, so it will me more wheelie happy.
    Jan 2004
    Palmetto,Florida
    2,300
    Quote Originally Posted by Aussieduner
    Aussie
    DANG !!!! L@@k's like you need some Stainless Peg Bolt's and a Stainless Swinger Bolt to go with all that PURTY Red and Alluminum !!!
    and.......................... i have made Stainless sleeves for the TRX Stuff to fit ATC Linkage.................
    "07" DR650 Suzuki Dual Sport
