Thread: pull rope
    Feb 2003
    Delano, CA
    616
    pull rope
    I need a new pull rope for my 110. It's like $13 dollars at the honda dealership. I've gone through like 4 different kind of rope. Does anybody know good rope to use or should I buy a new one from honda.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Rod's Avatar
    Rod is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    grants pass, or
    235
    $13 bucks sounds like a no brainer to me. Then you can be sure that it's right & you only fix it once.
    1985 tri-z needs a little work
    2003 400ex
    1999 yamaha warrior, for sale
    2006 yamaha raptor 700
    1986 atc 500r wrecked & mostly parted out
    1984 yamaha pw50
    Apr 2002
    s.w. michigan
    6,498
    pu;; rope
    it's been a long time since i have messed with pull ropes but seems to me a marina would have decent enough nylon (anchor ?) rope bigred110.
    don't know what you been buying but would go with a nylon type and not loke clothes line stuff.
    john
    p.s.- i would have a problem paying 13 bucks for a short rope too !
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I had Probs with my 110 pullstart, If you make sure it is at least 2 meters long it won't top out when you are pulling it and snap the knot off the end on the pulley,
    I just use thick lawnmower pull start cord, I Havn't had any problems since.
    Nat
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
