Results 1 to 15 of 20
Thread: seating a tire?
    az
    2,001
    seating a tire?
    Okay I got the old one off easy enough, but the new tire came in with the label wrapped around the tire and kinda deformed it. The tire is on the rim now but since its kinda deformed it won't seat. I wrapped a cord around the circumferance of the tire and twisted it, Will this thing come back into shape in a day or two? How about the gas or starting fluid trick? Anything to watch for? Jim
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    if its inflated it will retake its origanial shape. But if its not it probably wont, maybe let it sit in the sun, if you have any.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Aug 2006
    I bounce the tire and rim on the floor workin my way around the circumference of the tire. Sometimes I'll use a to beat on the tire while trying to inflate air at the same time. The number 1 thing is you dont want it jumpin the safety bead if you use the starting fluid.. good luck
    1985 350X
    1986 250ES Big Red
    (previously owned) '89 Cr 250R
    2008 Toyota Tacoma Double Cab
    Apr 2006
    PA
    1,464
    I saw this one video of a unseated jeep tire a while ago. When it came off in the woods they sprayed bus spray on it and lit it. I guess the heat made the bead seat?
    Kansas City, MO
    93
    The starting fluid trick works, kinda scary the first time you do it. Kinda fun after that.
    1985 Honda Big Red
    1983 Honda ATC250R Sold
    1979 Trail 90
    K0 US90
    My atv parts on ebay: http://search.ebay.com/_W0QQfgtpZ1QQ...QQsassZbikerdg
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Ok i have no clue what the strater fluid trick is but im guessing, you take the inside is the stem out. Spray some starter fluid in. Light it up and hope the pressure seats the tire?
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Sep 2006
    rochester nh
    26
    Sep 2006
    rochester nh
    26
    this one is not as slick but shows it http://www.youtube.com/watch?v=SIVLQCZJGAw&NR
    Pa.'s Highest City
    8,058
    aaah yes...
    Quote Originally Posted by crownpoint
    A how to blow yourself up video! I've used this technique a few times. I would not recommend lighting the stream of fluid on fire though... and gotta remeber that guy is doing it to a huge truck tire. I would think a one of two second burst inside the tire would be suffiecent for an atv tire. I also do it by tossing a lit match.
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Wow thats awsome, it seems like it even airs the tire up 2?
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Las Vegas, NV.
    2,514
    Quote Originally Posted by super90
    What the hell is bus spray? Is that some sort of aerosol repellent to ward off those pesky city busses?
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    Yea about a 1 to 1.5 second blast is all you need for ATV tires. The way I light it is lay a little strip of ether out from the tire and hit that. It travels to the tire and........done.
    I leave the valve core out, and spray into the bead area most of the way around.
    If you don't get carried away, and stay back a little, it's pretty safe, but according to the CPSC...........
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Aug 2006
    Texas
    997
    Quote Originally Posted by InPiEcEs
    ....it's pretty safe, but according to the CPSC...........
    84 Honda 200ES Big Red
    Aug 2004
    Ab Canada
    4,368
    Make sure to Deflate the tire after it has Seated with the Starting fluid, Not good to have explosive Gas in youR tire. will cause it to expand more when hot and whatnot.
    1985 Tri-Z-
    Jun 2006
    Cushing,Mn
    538
    Cant wait to try it,looks like fun!!!!
