Alright. I had to buy another carb for my 250es because the original one had the pilot jet cranked in so tight it ended up breaking apart trying to get it to back out.
I set the pilot jet on the new (used) carb two turns out and installed it.
Now I can get it to crank up and stay running for a minute or so, but the idle is very high and then quits.
I checked the throttle cable and it's routed right and not binding. Choke cable also works.
I have a question about the vacuum lines. Do they HAVE to be hooked up to the "T" like is shown in the manual to run right? Mine doesn't have this T and where does the vacuum lines go after going to the T? The manual doesn't show this. Also, I need to clean the petcock because it leaks in the RUN position. But with the fuel line off and in the RUN position there is a constant flow of gas. I also did not have the air filter on the element, but did have the airbox lid on.
Now would the problems listed above cause very high idle and then cause it to quit running after a minute or so, then make it hard to start?
I now have a new air filter and am going to clean the petcock hopefully today. I need to know about the vacuum lines on the carb. I think there are 2 vacuum ports on the carb. The manual shows these 2 lines going to a T fitting, then a line leaving the T and going somewhere???
