Results 1 to 9 of 9
Thread: bead wont seat w/innertube
    Aug 2006
    Texas
    997
    I put an inner tube in and aired it up to over 10psi. The bead wont seat on the inside and outside. I did slather it down with dishsoap. Id go more, but am afraid the tube will pop. Im already on the second tube!
    What psi are the Chen-Shin tubes good to? Any tips on getting the bead to seat?
    84 Honda 200ES Big Red
    Jul 2006
    put in 40 psi it will go finally, use pb blaster of wd -40
    Sabula,IA
    620
    The tube is supported by the tire or it would never even hold 10 lbs. Sometimes it takes as much as 25 to seat them. Undiluted dish soap makes them slide on much easier.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Aug 2006
    Texas
    997
    I just put about 15psi in there and got the outside to fully seat. The inside still isnt budging. I am using a little ashtray powered air pump. Think it will go better if I take it to the local gas station air pump?
    Jul 2006
    dude bring it over here!!! I GOT 175 ON TAP!! and I'm closer than a sation foool!
    illinois
    743
    lololol you guys are funny lol
    try a little wheel grease around the lip -/or vasilene petrolium jelly --verry lightly
    it will keep them from corroding and dryrotting
    and will seat easier with less air
    PSI is PSI no matter where you get it. I won't buy Chen Shing anything but it does the trick... You can air that up plenty without a problem and use the lubricants these guys mentioned, I like dish soap.
    Aug 2006
    Texas
    997
    Whats a safe psi? I dont want to blow my last innertube!
    Jul 2006
    ive had 60 in a tube before so......
    I say go for it, or bring it over here, I may have an extra 8 inch tube
