Thread: 200X Front-Caliper Compatibility?
    Oct 2006
    Eagle River, Alaska
    Will a front caliper from an '86 200X fit on an '84? How about from a 250R? Need to know if the bolt holes will line up.
    If you have an 84 then the 83 to 85 calipers work. BUT, I believe that the 86/87 caliper will work if the 83/85 bracket is used. The "R's" don't fit unless they are the earlier years - I have an 82R front caliper that fits my 85 200X front. The older rear R calipers swapped sides with the chain and are different.
    Jun 2003
    englishtown NJ
    2,676
    I have a 86 200x caliper on a 84r setup, it fit right on, no changing of anything.
    Oct 2006
    Eagle River, Alaska
    Thanks for the help guys.
