Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: S.Steel brake lines
    As a machinist and fabricator myself, I think your setup is pretty sweet. Half the fun is getting it just the way you want it!!
    Where do you buy that brake line material and also the ferrule and what size is the ferrule.
    Only thing is most lines are just under 3 feet so 24$ just for the inside line seems expensive. Then I need the ends so I'd have to buy crappy lines and rape them.
    Still pretty slick though.
    Apr 2006
    oakridge oregon
    124
    I am sure that you can find it cheaper somewhere ,but A-1 Coupling & Hose in Eugene Oregon (541-485-7133) is the only place i`ve found that has bulk S.Steel brake line .The ferrules are just scrap copper or brass that I turn down to .575in x1.25in long .I just use the old brake line and cut the fittings off,you can make them in a pinch if you need to.
    Jan 2004
    Palmetto,Florida
    2,300
    i get mine from Amazonhose.com............
    "07" DR650 Suzuki Dual Sport
    Apr 2006
    oakridge oregon
    124
    Quote Originally Posted by Yamahondaman
    Thanks for the heads up.I will check them out Monday , was about to order a 52in line maybe I can save a few $
    Apr 2006
    oakridge oregon
    124
    Thanks again, was able to order brake line from Amazon Hose (Tampa store) for $3.18/ft + shipping .Worked out to $3.60/ft delivered,better then $8.25/ft
    Lancaster, PA
    1,738
    Nice idea , Here is what I did to make up a custom line. Russell makes chrome fittings that thread into a SS line that is plastic coated. The lines already have the ends crimped on and are avaliable in many lengths. Just order the ends you need and the length of the line and you are done. Akso you can get fittings to add in a brake switch if you like.
    http://www.russellperformance.com/mo...sMetricCat.pdf
    Page 17-18. I used the -3 fittings not the compression fittings. Its super easy!!!!!
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Quote Originally Posted by blue27 View Post
    Linky no worky!!
    Lancaster, PA
    1,738
    sorry thats what I get for not double checking!!!
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
    Apr 2006
    oakridge oregon
    124
    S.Steel brake lines
    Looks like a good simple system to use
    Dec 2007
    521
    where did you get the dye?
    Apr 2006
    oakridge oregon
    124
    Rit Dye
    the simplest way may be to go on line at Rit Dye and order what you want . I got mine on line and at a Bi-mart store . It may be at a Target, fabric , or other large chain store.
