I have a 1986 200S that is running rough at idle and at low speed. i have cleaned the carb also adjusted needle valve several times, it seems to be running a little rich no matter how i set the carb.when at idle it is spuddering, no popping or back firing can not figure it out. also it seems to have plenty of power.
had will also explain in more detail,I believe'That's good stuff !!!
