Hi folks,
I just got my 85/86 atc 250r disassembled for inspection... (When you have the feeling that it's time to invest before everything breaks...). I removed my cylinder and I had a bad surprise: A big scratch from the top to almost the bottom. My crank also seems to have some damage.
My piston is a wiseco 526p2 0.50mm over. I'm wondering how much oversizes left I have (86 cylinder)? Here is a pic or my piston, what is the cause for all the small holes on it?
The cylinder... we can see the large scratch in the middle. I don't know what got blasted in it... Is it possible that it will need to be bored 2 sizes over the get rid of it?
Here is my crank. It is just in that position that I can see it's damaged. My bike was running fine though. The rod has no play up and down and a slight play left/right, is it normal?
My head seems ok excepted for the carbon... What is the cause for such accumulation?
The previous owner had grinded the inside of the intake as you can see. Is it a good idea, should I grind it more?
Thank you so much for any help and sorry for my bad english.
