um, it looks like you need a whole rebuild, the dings on the crank are from someone using a metal
to true it, you're supposed to use a lead
, and the pitting is a peice of metal bouncing around, and wiseco pistons dont need extra clearance because they are "heavy duty" they expand slightly more because they are forged, not cast like the ghetto pistons like pro-x. and you can take the reed stuffer right out of that cage, it just snaps in, it will give you a little better top end, i dont know if you would be able to feel it on a stock bike though.....i say bore it with a new piston and do a new rod kit and main bearings/seals, if not a brand new crank and mains/seals...
