Thread: 84 R re-assembly question - axle
    Tionesta, PA
    5,747
    Can someone help me. 1984 ATC250R
    Here is what I did:
    Installed new bearings and seals in carrier. Replaced carrier in swing arm. slid axle into carrier until sprocket bottoms out against seal. (other side) Installed rear caliper mounting bracket. Installed rear brake disk with disk mounting hub - long side of hub goes into carrier. Installed 1 spacer/washer - installed 2 nuts on axel. Axle is very very sloppy after all is tight and axel nuts bottom out of threads.
    After looking at micro fische - I see that it looks like I am missing some other collar that fits between the brake mounting hub and the bearing seal. Can someone enlightem me??? There was nothing like that when I removed the sloppy rear end..........
    CUYAHOGA FALLS, OHIO
    1,242
    O
    Yup. You need that there. I dont see how the nuts would even come close to being tight. The collar slides on right after the brake disc hub, then the washer, then the two nuts. You are going to need one to get this set up rite and tite.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Tionesta, PA
    5,747
    Thanks Max - also after some research and seeing so much sloppiness is in the rear of this thing - I have found that 84 R axle bearings are not the same as 85 350X axle bearings. OD is the same - thus they fit in perfect and I assumed they were right - ID - is 5mm different (bigger on the 350X - I should do my homework on stuff like this BEFORE I assemble !!!LOL
    FOR REF:
    350X Axle Bearings = 40I.D. X 62O.D. X 12 Wide
    250R Axle Bearings = 35I.D. X 62O.D. X 7 Wide
    1,242
    Turd
    So what about the collar your missing?
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    Tionesta, PA
    5,747
    I guess I need to find one - or get one - I can't see that they are discontinued. Do you maybe have a spare laying around? Hint hint?
