Results 1 to 3 of 3
Thread: 1985 Yamaha 225 Tri-Moto
    Oct 2006
    Warsaw, In.
    4
    Is 30 psi of compression enough to make this atv run??I can't even get a cough out of it while spraying gas into the intake...
    rassagmc's Avatar
    rassagmc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    Port Deposit, MD
    173
    Thumbs down
    whoa, 30. i think your going to have to do a new top end because you need to get that compression up. get a head gasket, cylinder base gasket, and definately some new piston rings. also you want to make sure yourcarb is working. you might want to take it off(and apart) and soak it in some carb cleaner. also, make sure your spark plug is getting spark. but first of all , you need to get that compression up. the gaskets are cheap, but the piston rings will be more than you think for just those little things.
    here's the site where i buy my parts(they have really fast shipping)type in your make and model and it will give you a list of parts
    http://www.denniskirk.com/jsp/common...VSM4VMDK0NCIV0
    BIKES CURRENTLY IN MY GARAGE
    1990 XR80R
    1983 CR60R
    1986 250SX
    1985 250R
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    140 max psi compresion test.120 psi minimum.You need to have it at operating temp before doing the test.You have to turn the motor at least 5 times to get good results.
    Got
