84 200x flywheel or rotor puller
alright fellas, i need to know what size and thread of bolt to use to pull this f'n magnet out... i know you can use your front axle bolt but my engine is a different place from the frame, and i would really rather not drive back and forth guessing which bolt, so if you could help me out id REALLY appreciate it
If I'm reading my catalog right it looks like 27mm x 1.0 L.H. Someone correct me if I'm wrong.
alrighty, i'll check it out and see, thanks
the front axle should be a 14mm 1.5 pitch.
so wait...what size bolt can be used?
//ArrowChat Integreation Code
