Thread: need advice
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    need advice
    My wifes 86? sx has no brakes at this time. I think the pads came apart from sitting up for a while. No big deal there, pads and springs are cheap enough.
    Now the problem. the p.o. put holeshots on itp rims, aluminum, on it. It looks cool, rides awesome, but...He also used tapered lug nuts.
    The lug nuts grabbed into the alum and shrunk it around the wheel stud, now they wont come off. I tried tapping them off with a block of wood against the rim and tapping it, no good. I tried loosening the lug nuts and riding it, didnt work either. I can use a puller of sorts but it will have to rest on the brake hub, which has been discontinued, see where this is going?
    Any way to get the rim and or the hub off so I can get to the brakes? Without breaking the hub, HELP! Dave
    Dec 2002
    deer park, texas
    2,336
    Have you tried to heat the rim around where the studs are. This will cause the aluminum to expand.
    Jul 2006
    western ny
    3,366
    yea try that. heat always works for me too.
    GIT IT RAAAGGGGG !!!!
    Jul 2006
    just use propane on it cuz if you use acelalane torch you could be seriously meesing up the aluminum rims!
    Jul 2006
    western ny
    3,366
    plumers tourch. works every time. and does little to no damage to the rims.
