Results 1 to 7 of 7
Thread: 85 Yamaha Tri-Z Headlight
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    Can anyone give me the part number for the left side headlight harness?
    My buddies tri-z's headlight quit working so i tore it apart and found that one of the wires going to the actaul headlight little circuit board thing has came unsolderd(sp). So basically we want to replace from the connecter from the main harness for that headlight to the headlight bulb.
    Thanks!
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
    you have to buy the whole assmbley so i would say e bay..
    Mar 2004
    194
    Whole Assembly?
    -1983 Honda ATC110-
    -1991 KTM 540-
    -1996 KTM 550-
    -1997 Honda Cr80-
    Jun 2006
    Illinois
    491
    I would try and fix it. Speaking of headlights, where can I get the correct bulbs for the Tri-z headlights?
    Aug 2006
    Arlington, Wa
    1,027
    I get the bulbs from the dealer, costs a bit more, but it is the right part, with only one stop.
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Mar 2004
    194
    I've already tried to fix it by resoldering it. I couldnt get it to stick back on.
    -1983 Honda ATC110-
    -1991 KTM 540-
    -1996 KTM 550-
    -1997 Honda Cr80-
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    Quote Originally Posted by Rennat_2006
    What type of solder are you using.. There's two types, plumbers solder which needs flux to bond the solder to a surface (also not a wise choose to use on wires)
    And the second is a resin solder that has flux already embedded into it (perfect for wires and electronics)
    The thing about plumbers solder is it will start eating away the wire.
    I use resin solder on all wiring fixes and electronics i fix (circuit boards ect.ect.)
