i have a 85 250sx. when i got it would bogg a little bit then clear out. so i got a moose carb rebuild kit and put it in today.
i clean everthing good and put every new seal, jet, etc.. in. it would start up and idle great but anything passed a 1/4 throttle would bogg out and shut off. i put the needle in every notch- nothing changed, messed with the one screw (forget what it called)- nothing changed, tried old jets with new jets- nothing. so i put everything that came out back in and put everything to the settings i started with but the needle because i dont remember the notch it was in, so its in the 2nd notch. now it runs like it did, just boggs a little more but clears out and runs fine.
i looked at the jets that came in it and there bigger then the ones in the kit. the ones it the kit match the jets it calls for in my manual.
so why does it need bigger jets to run? and how do i fixed the slight bogging? thanx for any help.
