HI Guys
I am new to the board and was wondering if you guys could help me out with some advice on my 86 atc 350x crank. The crank bearing went on it last weekend and I would like to know if I should get it rebuilt or buy a new one. Having it rebuilt is cheaper then buying a new crank by quite a bit but is the rebuilt crank going to work as good as a new one and or last a long under normal driving conditions. Also, does a 85 atc350x crank work or fit properly in a 86 atc 350x motor? I know the 86 had some changes to its internals so the oil would circulate better. Please , give me your advice in which is the best way to go.
Thanks K.H. :?: :?
