Results 1 to 10 of 10
Thread: need help!!
    Oct 2006
    north platte nebraska
    5
    Question need help!!
    I just got a 1980 honda 185 and im having alot of fuel blowing by the piston. its coming out of everywhere. behind the CDI cover, in the oil, etc... could anyone please tell me what to do thanx.
    kcop is offline New to the board Arm chair racerNew to the board
    Sep 2006
    WI
    22
    if the machine was ever flooded bad fuel can seep past the rings and thin out the oil, then lack of adaquate lubrication can cause damage. Tear it down and check top and bottom
    Oct 2006
    5
    thanks for the info. this is my first trike and im learning alot.
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    Make sure the oil is not full of gas. I bought a yamaha and it was doing this and the crankcase was almost full of fuel from a stuck float in the carb
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Apr 2006
    Crestview, Florida
    2,429
    i would say a bad float or needle valve . also make sure the fuel cap is venting.
    Oct 2006
    5
    i thought it was the float to at first. is the needle valve something that can be adjusted or do i have to replace it if it is bad? (how can i tell if it is bad?)
    Oct 2006
    5
    Thumbs up
    Quote Originally Posted by jeswinehart
    Have you checked to see if the tail pipe is plugged up and or crank case ventilation tube is plugged ? It might be easier to start there.
    Any history on the machine like was it sitting for years or recently running ?
    john
    it sat for almost 2 years i had to replace the prmary ignition coil. the tailpipe is not plugged and i will check the vent tubes thans for the info
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    A buddy of mine from work had a problem like this, His base was FULL of gas, it was sitting in his garage for about a year. The needle valve was stuck open and all the gas from the tank went into the bottom end. I would say in your case the needle valve is a good start to correct this problem where yours was sitting for 2 years.
    Oct 2006
    5
    Quote Originally Posted by troy
    thanks troy ill try that
    Oct 2005
    Pennsylvania
    863
    remove the carb and blow into the fuel inle...it should be clear, The flip it upside down and try again , it should be blocked.if either of these checks fail, rebuild the carb.It would definitely be advised to get fresh oil in it before you try running it.
    Buy American! Unless your only option is a HARLEY.
    A customer walked in to my shop and Impatiently stated "My car doesnt start, Whats the problem?"I responded with a smile-"Yep that sounds like your problem alright"----
