Thread: What's the difference between the '85 &'86 350X
    Nov 2002
    Ft. Wayne, IN
    81
    I've been looking for an '86 350X but i'm finding a lot of '85 350's What's the difference between them? I had an '86 200X and I can get that one back but I'd rather have a 350!!
    Thanks
    Methanol, the nectar of the gods!
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    There are a bunch of threads on this do a search of the forums...
    But off the top of my head
    the frames are different
    the rear brake is set up different
    85 has red plasitcs 86 is white
    86 bottom of the triple tree is black 85 is chrome
    clutch cables are routed different
    the carbs are different
    there is slight changes in the engines
    cam tensioner is different
    do a search this has been disscussed alot
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    Tionesta, PA
    5,747
    also - rear sprocket set up is different
    kb200x's Avatar
    Aug 2005
    KY
    295
    The 86 may be a slightly better trike but either year 350x is fine. I would not worry about the changes there is really nothing that makes either one better than the other. Honda did change a few things to try and improve on the 85 but nothing major. With that said make sure you look over the frame they are known to crack. Good luck on you search
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    Oregon
    2,471
    Yes Look out for bent fork's , and Crack's , and check the Case's
