Results 1 to 10 of 10
Thread: Anyone else have LA Sleeve probs?
    Sandilands Manitoba
    24
    I recently had my 85 Z re sleeved with LA sleeve and coolant has been spilling out of the resi jug breather since then. My machinist said I might have problems with overheating due to the thickness of the sleeve and the amount of boring he had to do. Has anyone else had this problem? Eveything else checks on the bike no leaks, impeller working well, heads not warped, rad looks good (clean in and out), reacts the same with thermo in or out, cap holds pressure. If I drive it like my wife would its o.k. but really what fun would that be. Any help appreciated.
    1985 Yamaha YTZ 250
    1988 Kawasaki KX 125
    1995 Yamaha V Max 600
    Brandon, Manitoba
    2,209
    Hey, just noticed you are in MB...dont know the prob with your Z. Sorry
    Where in MB are you?
    hey, try a jet change/needle adjust. may run a little warmer with tighter clearance.
    one cylinder is not enough!!
    potsdam NY (upstate)
    1,437
    make sure that your thermostat is working....yes if you didnt know the tri z has a thermostat just like a car does... make sure it works....
    Sandilands Manitoba
    24
    The bike reacts the same with the thermostat in or out and it is working correctly according to the test used in the manual. I don't think messing with the jetting is gonna help. My plugs are a nice choclate brown and the bike runs normally throughout the throttle range. I know others have used LA sleeve here. Let me know how it worked for you. Thanks.
    1985 Yamaha YTZ 250
    Jan 2004
    Palmetto,Florida
    2,300
    OH BOY !!!! the sleeve isn't lined up with the top alluminum part of the cyl. !!
    iv'e had sleeves "slip" down before...seem's like a "Friday" Job to me .....
    "07" DR650 Suzuki Dual Sport
    CUYAHOGA FALLS, OHIO
    1,242
    Oh Boy Is Right!!!
    Quote Originally Posted by Yamahondaman
    I had this happen on my recent bigbore build. The sleeve counter sunk a couple thou. I just took my studs out and sanded everything down flat. Granted, we are only talking 5 TO 10 thousands.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    illinois
    743
    mine was air cooled but i hadnt had any problems
    you can get some cooler antifreeze-- i think all of them could use it
    -royal purple-i think is one
    Sandilands Manitoba
    24
    Finally had time to take the top end down and I see the sleeve isn't lined up on one side but flush on the other. Its obvious now but the first time I had the head off it seemed fine all around. I will post an update when I get time to put it back together and have it runnin tickety-boo. Thanks for the suggestions.
    1985 Yamaha YTZ 250
    Jun 2004
    potsdam ny
    1,227
    take some pics of the cylinder, those sleeves have "hats" on them so they CANT go up or down when the head is on, if they did a crappy job which it sounds like he did it wont be even with the top deck of the cylinder. the thickness of the sleeve wont affect the cooling of the motor enough to EVER notice, sounds like you have a popped head gasket to me and you are jump pumping the radiator with pressure thus pump antifreeze out of the overflow...but i wouldnt be able to tell you for sure without a pic...
