i have a 1985 250r that i love.
i just came across a 84 air cooled one for 650
im going to look at it tomarrow
is it slower then the 85?
what are the down sides to this one?
yes it is slower but not by as much as one would think if both are in top form.
downside, parts are starting to get hard to find, mainly on the chassis. you can still get all the motor parts pretty easily.
upside, extreme ease of maintnence(sp), everything on the trike is opened up a bit more than the 85's. I personally like the 83-4R's over the 85's, they sound different, they have a lot of raw grunt torque that I cant get enough of and if you take your time and build one wisely they can be just as much fun to ride as the 85's
1985 KXT 250![]()
84 KX cylinder
sprock racing head
+2" Miltech swingarm
frame mounted Rad
1983 250R![]()
DG head
290cc Big Bore
CT pipe
85R front end
+1" Miltech swingarm
2+2 axle NOS NASA
18x10x9 Hoosiers
i have both 85 and 83..my friend used to own the 85 and back then i beat him on a track with my 83, mine was stock and his had a fmf fatty on it, we are pretty much the same riders.
i only bought his because well its another 250r and with thte parts i have now, the air cooled would over heat in 5 minutes
You should buy it if its in decent shape!!!!!!!
'85 ATC 250R
FMF Fatty & Power Core
Boyesen Rad Valve
38 PWK A/S
K&N w/PF (next purchase)
LSR +4 Axcaliber axle
LSR Duel row bearing carrier
DuraBlue Anti-fade (to be installed)
13/36 sprockets
'85 ATC 250R
Parts trike (maybe future build?)
