Thread: difference between 85'-86' 250R's?
    Feb 2006
    connecticut
    95
    could someone tell me what the major difference is between the 85' and 86' 250R's? i just picked up a project but im not sure how to tell what year it is. thanks
    OSR is offline New to the board Arm chair racerNew to the board
    Sep 2006
    PENNSYLVANIA
    31
    1986 will have a gray motor, black top triple clamp, and says "ATC" on the side of the seat.
    1985 has a black motor, both triple clamps are polished aluminum, and it will say "250R" on the side of the seat.
    Also, the 85 rear shock canister has a black knob on it and the 86 has a gold one.
    hope this helps
    O S R
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,250
    do a search, on this site mmmm there are several threads for this . all the info you will ever need is here just look for it,,,,,,,,,,
    Aug 2005
    Portland Or
    412
    86 also upgraded to a flat slide carb.
    "Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut."-Ernest Hemmingway
    Feb 2006
    connecticut
    95
    thanks guys
    Jun 2003
    englishtown NJ
    2,676
    the major differences is: 86 has more rake, 86 has more fluid in the forks, 86 uses a 86-89 carrier, axle, brake hub, swinger, sprockets, 86 peg plates can accept 86/87 trx250r, 86/87 200x, and 350x foot pegs, 86 has less gussets in the frame, 86 uses a different cdi and harness and there is a huge laundry list of small stuff. Both are good bikes don't turn down a 85. You have to ride a 85 and 86 back and forth to really see the difference for most poeple(I notice every little thing)
