I just bought this pipe and silencer for my 84R. Can anyone tell me what I got. I got a good deal on it - and am replacing it for my stock one that I currently have on it. Plesae help me ID it. I hope someone can help me.
i got one of them at home i will tell you later.
i want to say hoffman or something like that but i just cant put my finger on it.
will I need to change jets or anything with this pipe swap? All intake components will remain the same - (Stock).
When I put my dg on my 84 i went up a jet size or two. You probably should too. Your pipe might be a bassini. I havent seen any other options for the air cooled. The factory pipes are way restrictive. You will notice a huge gain. I ran a k&n on mine and drilled a few holes on the top cover.
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
2011 KAW SXR800- 35YR EDITION
05 HERITAGE/SPRINGER/SOFTTAIL
do you = yes
does everybody = no
will it hurt the engine = maybe
will it get full benefit of the new pipe if you don't = no
the thing will probably be a little lean if you don't rejet. maybe not enough to hurt anything but it might. and the thing will run better when jeted corectly
Hoffman? Do you mean coffman? i have one of those, mines for a 200x
i think that is it. the name plate on the 2 stroke scilencer is smaller but it is the same color scheme and thick plate style i think that is it. i would bet mine says cofman also. cool thanks.
is this a rare desirable piece of 3 wheel racing history?
Tim, i'd swap to a bigger carb to complement that pipe. Look for a nice 34 or 36mm on ebay. I noticed a BIG power gain in my air cooler by swapping carbs.
what carb comes stock on and air fooler? What carb is a 34 or 36mm? 85 / 86 250R?
Thanks guys.
The aircooler has a 30 or 32mm. Can't remember which. The 85-up 250R's have 34mm carbs, 85's being roundslide the rest flat slides.
