Results 1 to 8 of 8
Thread: carbs for 200x?
    Oct 2005
    saratoga, ny
    2,819
    carbs for 200x?
    what carb are you 200x owners running on your trikes? what is the best performance carb, biggest size, etc....
    Jun 2003
    englishtown NJ
    2,676
    I have a 27mm pd carb on mine
    Oct 2005
    saratoga, ny
    2,819
    wow one response from all the beloved 200x owners. thanks guys, was wondering what options are out there besides the 27mm.
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I am thinking of putting a 28mm flatslide on mine, there was a dg article floating around on here about a DG kit that used to come with a 28mm mikuni flatslide, that with a cam and a pipe, made the ol' x "scream like a banshee".
    DG sells a keihin I think, possibly the 27pd deathman is talking about at http://www.dgperf.com
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Sep 2003
    Elizabethtown PA
    1,581
    my 85 200x motor i used to race that was in a trx250r chassis used a 32mm Lectron carb. it was a TC racing motor with a 13.5 to 1 compressoin really bug cam and lots of port work. it was a dual plug motor.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Jun 2003
    englishtown NJ
    2,676
    thats the one, it performs good. Some loss of bottom end. Without alot of work done, any bigger than a 28mm is too big. My 86 200x is getting more motor work, so we'll see if the 27mm needs a bigger one
    Jun 2003
    englishtown NJ
    2,676
    Jul 2006
    galway ny.
    534
    im using a 27mm and it purrs with the xr200 cam''
    85 tecate 86lt250r
    85atc 200x
