Thread: Custom Wire Harness for 200X
    ATCR250R's Avatar
    ATCR250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Norfolk, NY
    319
    Hey all, I was wondering if my plan for a custom harness for my 1984 200X is on the right track or not, any suggestions would also be appreciated. To start I was planning on retaining some sort of headlight, right now I am thinking a 350X dual beam model. Also I want to use this bar switch from Dennis Kirk with kill and hi/lo headlight functions. I would reuse the connecters I have since I sure do have alot to choose from and splice in new wiring then crimp and then tape the splice points. After that I would wrap pretty much any wires I could with that thick plastic stuff like this. Does this all sound like a good foundation for the harness or not? If not what do I need to change? Thanks!
    ATCless at the moment...
    1977 Firebird Formula
    1997 Suzuki RM250
    ATCR250R's Avatar
    Norfolk, NY
    319
    Hmmm, I was just doing some research and it seems I need a voltage regulater/rectifier in there as well... How do I wire this up to work and what can I get one off?
    1997 Suzuki RM250
    ATCR250R's Avatar
    Norfolk, NY
    319
    No answer yet? lol I may have to just dive in to the project... Or or should I just attempt to mod a stock harness for what I want? (350X headlight setup, the kill mentioned, no taillight)
    1997 Suzuki RM250
    Sep 2006
    Albert County N.B.
    55
    im pretty sure the voltage regulator/rectifyer is for electric start.that split loom stuff is huge and doesnt work well for harnesses especially where the harness branches off.you'd be better off with shrink tube(much cleaner looking)also if you can find it there is a product which is liquid electrical tape that you put on with a brush and it hardens,i get it from princess auto which is a canadian store.that kill switch shouldnt be hard,headlight could get tricky thou
    86 250 sx-my baby
    86 250 es-needs little work
    83 atc 110-frame up resto
    82 nighthawk 750(for sale)
    Oswego, IL
    1,858
    you can easily mod a stock one to work with a 350x headlight. i did it on mine. your idea should work fine ill check out my harness after school and let you know. i was going to do this but for some reason i thought there was some type of connecter you needed i dont remember. ill check my harness out wile i still have it and let you know. but yes the srink wrap or this stuff i have looks pretty clean ill get some pics to show you.
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    troy's Avatar
    troy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Canada
    254
    Quote Originally Posted by PitboyJohn
    Your right, the rectifyer is used to allow current to go one way and one way only, Example from the engine to the battery, with out it the current will try to fight to go both ways. Also it's suppose to convert the AC power coming from the engine to DC power for the battery. The voltage regulator is to keep the power to 12 volt only. Most bikes with electric start have both bulit together. If your bike doesn't have eletric start you won't need a rectifyer, unless your going to run some thing that need DC power, like a L.E.D lighting kit.
