Results 1 to 15 of 16
Thread: Lets see this on a 250R at the TF drag strip!
    Nov 2002
    Kirkville, NY
    3,831
    This could be fun!! Wonder how well it works?
    http://cgi.ebay.com/ebaymotors/250r-...45420246QQrdZ1
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jan 2005
    Jones, Michigan
    1,821
    DAMMIT! everytime i see something out fo the ordinary and i want it....TRIZTUNES has already bid on it or bought it I know hes always willing to pay more than me too so i might as well not bid.
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Jan 2004
    Palmetto,Florida
    2,300
    COME ON WITH IT !!!!
    How Bout it Raffa,Billy,"Green Thing",Jason,Nathan,Kintore,ETC !!!
    "07" DR650 Suzuki Dual Sport
    May 2005
    Southern NH
    1,489
    if its powered by a pully that would make it a superchrager. If it even does work, that's proubly not good at all for the engine!!! Instant time bomb!!! Proubly would give the machine the reliability of a 350 kit with less than half the performace gain lol
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Anaheim, CA
    517
    LMAO that looks so home-made its not even funny. even if it works its so ugly i wouldnt install it on my trike, unless i had a full face helmet with a tinted screen.
    83 250R
    91 CR125R
    Columbia
    5,131
    I love how the auction states that it adds another gear to the bike! It would be pretty crazy to put a turbo on a pinger, I could see it on a 4 stroke though....
    Oct 2006
    south florida
    147
    this thing on ebay is total BS.
    it is somones abandoned prodject.
    it is a canibalized turbo made into a supercharger.
    and there is no lubrication to the bushings.
    i got a link here to something very cool. and it looks like he riged up a little oil curculating pump for the turbo.
    http://video.google.com/videoplay?do...35400295297703
    heres a cool little one. http://www.mjmturbos.com/images/SMALLEST.jpg
    http://www.btinternet.com/~goosegog/turbodax.htm
    Jan 2004
    Palmetto,Florida
    2,300
    Like i SAID ................ BRING IT ON !!!!
    a little "stock" 250 ON GAS will take the $$$ Home !!!
    Jackson MI
    1,688
    When you get Into those kid of mod's you better know whats going on, because you make so much more work for yourself. All I can say Is TRACTION Baby
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    TRIZTUNES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    PA.
    150
    Lets see this on a 250R at TF drag strip!
    Hi,
    I see you found my new toy.
    Not trying to make anyone mad.
    some of people made statements; and do not have a clue how this thing works.
    first check this guys feedback you will see the original owner.
    this guy never used it.could not fine a belt.
    no it is not a turbo this would be consider a supercharger.
    to be a turbo it has to driven by exhaust pressure.
    were a supercharger is driven by a pulley.
    one of the advantage a supercharger has over a turbo: is a supercharger makes boost at any rpm, were a turbo only kicks in at a higher rpm.
    as for no oiler :does not need one,it will be lubercation by the gas and 2 cycle mix.the carburator mounts to the outside of turbo unit.
    now in theory this should work but there is no garuatee.
    now the only problem i see is to get jetting right.
    for being hard on the engine no!!! will only make between 10 to 15 pounds of boost.all this unit will do is force the fuel and air mixture in to the cylinder faster.
    This thing should really rip!!!!!!!
    WE HAVE A SAYING AROUNDED HERE: IF YOU CAN'T KEEP UP SHUT UP!!!!!!!
    THANKS TRIZTUNES!!!!!!!!
    SAVING ONE 3 WHEELER AT A TIME!!!!!!!!
    CUYAHOGA FALLS, OHIO
    1,242
    Go Triztunes
    I really like this guy!!!!!
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Oct 2006
    south florida
    147
    10 or 15 punds of boost is alot of boost! i doubt it will make 5 PSI
    good luck with the lubrication.
    post your results with this thing are you working on it?
    gates should have a belt to fit anything . check out there site maybe.
    that was a turbo at one time.
    turbos have bushings in the center section between the inducer and exducer housings. the shaft floats on preasurized oil that is pumped into these bushings and there are seals out side of these bushings to keep the oil in.
    that makes me wonder what was done to get gas oil mix behind the turbo wheel and in to these bushings? even if there has been a way worked out it will still destroy its self in no time, the bushing cant take that little lube. maybe he put ball bearings in there , that would work. some high performance turbos come with bearings. i dont think this one did. maybe he machined it out and fit some.
    where do you hook up the belt? do you remove the stator cover and wrap it aoround the fly wheel?
    put up some more pics if you could. this thing is interesting.
    Jan 2004
    Palmetto,Florida
    2,300
    Quote Originally Posted by max
    HUMMMMMMMMMM...........
    Aug 2004
    PA.
    150
    Hi,
    this is only a single blade turbo.
    the turbo you are talking about is a duel blabe,one on intake side and one on the exhaust side.this is the one that bushings in it.the exhaust blade drives the intake blade.that is one of the reasons for a waste gate valve.
    and was oil cooled.
    this turbo what ever goes in comes out.kind of like a blower.as the engine revs down so will this.My only question I have right now is should I run a turbo crank to help push the burnt fuel out.
    this was a aftermarket item.
    do you see the pulley with the 3 holes in it that bolts to the flywheel.then the bracket bolts to where the stator cover bolts.then the square end bolts the the reed cage.I'm going to have to make a gasket for here.the carbuator
    will being sticking out the right side(the only thing I do not like)I will use a bolt on filter.I'm also going to try to make a cover or guard for it.
    I have not recieved turbo yet.My friend scott at northeast turbo said he would help also.
    As for a belt I will try tunnessen"s automotive(napa dealer)they deal in small engines also lawn mowers.I can also try bearing and drives unlimited.I do not think a belt will be a problem.yes I will be running a fuel pump.
    THANKS TUNES!!!!!
    Infinity Cycle Supply LLC.'s Avatar
    Infinity Cycle Supply LLC. is offline Formerly: rangerover,EASTCOATATVLLC Arm chair racerJust too addicted
    Nov 2005
    Avon Lake Ohio
    564
    uhhhhhhhh
    Quote Originally Posted by TRIZTUNES
    Hi,
    and was oil cooled.
    THANKS TUNES!!!!!
    UM?? A WHO BLADE??
    A turbo is dual blade or it isn't a turbo................ If a produced product has two blades and is driven by exuast it is a turbo. If it has secondary screws or an impeller it is a supercharger.
    That is a turbo with the driven impeller removed and a pulley put in its place. I am unsure what plan of gearing change this guy is planning but that turbo has to probably spin around 180,000 rpms and if driven from an atv engine there is gonna have to be radical pulley difference probably requiring 15 HP to spool the turbo correctly. It will do absolutely nothing but cause problems.
