Results 1 to 7 of 7
Thread: 1984 honda cr80 smoking with new rings
    May 2003
    51
    Ok I have a cr80 that was smoking and blowing oil. Oil was actually dripping out of exhaust pipe. So i had it bored out and a new piston and rings and it is still smoking and dripping oil. Anybody have any ideas?
    Matt
    mean350 is offline Just Too Addicted Arm chair racerJust too addicted
    uniontown pa
    472
    i bet your mixing the gas and oil too heavy
    Manheim, PA
    5,817
    run it 40:1 32:1 is just to rich and you'll go thru plugs. anyway if you didnt repack you silencer you should do that about every year to avoide oil flying out.
    potsdam NY (upstate)
    1,437
    2 strokes are suposed to smoke.... and the dripping out of the silencer and at the jug is normal over time...... that is all normal....no reason to rebuild it.... lol
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    illinois
    743
    change the silencer packing,
    use good oil,i use klotz 40:1 great oil--it burns clean
    the oil isnt burning,either too much,or crappy oil,possible too much back pressure
    if its a new top end the oil still is in the silencer packing ,and could be holding in too much back pressure,and it is still in the pipe, it will take time to burn all of it out
    be carefull not to go too lean because of this!!, oil cakes inside the pipe and silencer
    Sep 2005
    Canada
    71
    Repack the silencer and go a little learner with the mixture. If it persists you will have to rejet.
    - Kevin
    2005 Suzuki RM-Z450
    1991 Suzuki RMX250 SOLD
    1983 Honda CR80
    1984 Honda ATC250R
    1983 Honda ATC250R SOLD
    1975 Honda XL350R SOLD
    Hi,
    I know it's a bit too late but if you haven't figure it out yet you should try to check your OILSEAL in the crankcase as well as the water pump seal
    I have a 2001 honda cr80 and I had the same problem I changed everything possible but I never checked the oil seals.
    When i check my Oilseal it was not even in place WTF ! Maybe too much pressure in it or too old
    Cya
