Results 1 to 8 of 8
Thread: ok fellas, help me out
    aquapunk's Avatar
    aquapunk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2003
    borger, texas
    210
    Exclamation ok fellas, help me out
    alright, so after 3 months, i finally finished rebuilding my 84 200x , i had to replace the crankshaft, (i'll post some pics later of the damage ) along with other stuff, so i put it all back together, followed my book every step... and im 99.99% sure that i got everything timed right and t.d.c. so its all put back in the frame, ready to go.... its oiled and gased up... but when i kick it, it doesnt fire up.... it backfires every once in a while, usually when i hit the throttle while kicking.... its got spark too, nice blue spark... ive even tried starting fluid... no dice.... its about 55 degrees out here... so do i need to choke it, and also i dont remember if choke is moving the lever up or down.... i really was hoping to go hit the riverbed today, so if y'all could help me out, i'd really, REALLY appreciate it
    Apr 2006
    PA
    1,464
    The choke is in the off position when its down. Its on when it parallel to the carb. Did you spray the starter fluid straight into the engine or through the carb?
    aquapunk's Avatar
    Aug 2003
    borger, texas
    210
    straight into the engine,through the spark plug hole
    Nov 2006
    Borger, Texas
    3
    this is aquapunk, im at my friends house on his account, i followed everything the book said to do, so i really dont understand whats goin on
    Apr 2006
    Crestview, Florida
    2,429
    try pooring a small amount of gas in the cylinder and cranking it. starting fluid evaporates fast . as for the choke, up is on. double check the timing on the pulser and the f mark.
    aquapunk's Avatar
    Aug 2003
    borger, texas
    210
    well, i guess the pulse generator is out of timing.... im thinkin about selling it off... how much could i get from it the engine is basically brand new... rear fenders are cracked, and theres a dime size wear spot in the rear of the seat... the rest of the stuff is in my sig
    ATCR250R's Avatar
    ATCR250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Norfolk, NY
    319
    You are so close to victory, timing isnt that bad once you know how to do it. I wish you were closer I would time it for you but just keep working at it and you should have a runner real soon.
    ATCless at the moment...
    1977 Firebird Formula
    1997 Suzuki RM250
    aquapunk's Avatar
    Aug 2003
    borger, texas
    210
    oh, im not sellin it cause i cant time it, like afterwards, i've had this for about 2 years, and im really wanting to move to a stronger trike, possibly a 2 stroke? i dont know, i might keep it... kinda grown attached.... ive tried twice to get the timing right, but maybe thats not the problem... after the 2nd try, my spark plug is getting some black on it, whereas before it wasnt doing anything... when timing it, i pull the left cover off, so i can see the timing mark for the crank, and it lines up with the mark on the top, above the cdi cover... and im lining up the pulse generator with whatever its called, *brainfart*... this is right, isnt it?
