Results 1 to 9 of 9
Thread: Need some help - idling
    Tionesta, PA
    5,747
    Hi all -
    Question:
    I am working on a 1982 ATC200. When I got it - it had some electrical problems. Got them all straightened out and have good spark. Now when I start it up - it revs to the moon. It is not throttle cable related for sure. What else should I be looking for? BTW - I have the idle screw backed all most the whole way out. When I adjust it - it has NO effect.
    Help me please.
    Tim
    Mar 2004
    North Central Ohio!!
    2,712
    Sounds to me like you have a serious air leak. Try putting your hand over the back of the carb to restrict it, then try it.
    burnoutboy's Avatar
    burnoutboy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    New Zealand.
    352
    Yep.. all 3 of the Atc 200's I have owned all had cracked intake manifolds and caused them to rev really high.
    Apr 2006
    PA
    1,464
    I accidently did this to my 200x when i first had it, the carb slide needs to be positioned so the little slot fits into the groove in the side of the carb. When i gave it gas it revved high like that too and stayed. Could be that simple, or coule be an air leak.
    Sep 2006
    S.E. LA
    700
    Quote Originally Posted by super90
    I had a similar problem with my 250es carb. Butterfly valve wasn't closing all the way. Simple adjustment corrected it.
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Rittman, Ohio
    6,276
    My first thought too. The thottle slide may be rotated 180 degrees which will allow the top to go on carb, but it is held wide open.
    Sep 2005
    Northwest Ohio(Forest)
    974
    Is it low on gas or is the gas off, or even clogged? All my trikes always reved super high when they were nearly out of gas
    '86 200x
    theonlyjosh's Avatar
    theonlyjosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    Ontario, Canada
    276
    well my yamaha i am sure it is the choke, because when we first start it, it revs " to the moon" and after a few mins of riding it the thing idles... when it was inside it started up first pull and idled, and now we leave it outside and it revs until it's warm... so i am like 90% sure it's choke issues.
    I am a diehard Ford/Honda guy.
    Previous Trikes:
    1983 Honda Atc 110 (Stolen)
    1985 Yamaha 200N Tri-Moto (Sold to dad)
    Dream Trikes:
    1985-1986 Honda 350x
    Current Vehicle:
    1993 Ford Ranger XL Regular Cab, 4x4, 3.0 V6, 5 Speed.
    Dream Cars:
    1990 Ford Mustang GT 5.0 (Manual)
    2008 Ford Ranger Ext. Cab 4.0 5 Speed (Fully Loaded)
    Tionesta, PA
    5,747
    Thanks for all the replies guys. This was first one for me. After 2 hours of carb off carb on / cleaning carb / inspecting intake boots - It was the freaking throttle cable.............I inspected it all over and about a foot down from the thottle (near the frame neck) there was a ring of black tape. I removed the black tape and the cable was damaged there. I replaced the cable and VIOLA!!! normal idling and reving.
    Again - thanks for the helpful suggestions.
