Thread: 86 250r, need rim size recommendation
    Oct 2006
    Ohio
    47
    I just bought a set of ITP holeshot HD 20x11x9 tires for my 250r and I want to eliminate the gold rims and go with Douglas Red Label, but what size rim do I look for to fit these ITP's? I'm pretty sure the 9 represents the rim size right? so I need a 9" rim with 4x110mm bolt pattern but what width and offset do I get?
    Thanks!
    Michigan
    1,220
    Quote Originally Posted by brddog7683
    Thanks!
    You need a 9"x8" wheel for those tires and yes you are correct, the 9 represents the wheel size, 11 is width of the tire. I don't think there is an option for offset with the red label wheel but check different sites. The wheel will come with either a 4/4 offset or a 3/5 offset, I can't remember which. Ask when you order them.
    Rittman, Ohio
    6,276
    The most common choice for your application will be a 9x9 with 3"+6" offset. The first number is the tire bead size, the second number is rim width. The offset is how far from the center of the wall is that the hub bolts to. An offset allows you to gain width, or by flipping the wheels, you can reduce width.
    Rittman, Ohio
    6,276
    I posted at the same time as X.system, and his info directly pertains to the specific Douglas rims you asked about. The info I posted is general rim info, so his should be more helpful.
    Oct 2006
    Ohio
    47
    thanks guys for the info!..appreciated
    Oct 2006
    Ohio
    47
    Ok, I have one other question since I was told about either a 9X8 or 9X9. Either will work but will the 9X9 keep the tire at a more 'flat' profile than the 9X8. Probably pretty minimal huh? Just thought I'd ask though....
    Nov 2006
    Florida
    1,663
    Just a bit, if you want some flat ones get some 10's it would be wider for the bike to and help with stabiilty..
