I am finally getting around to installing my 300 kit on my 83 250r.the stock head gasket is way to small.does anybody know where I can find the correct 7 stud copper gasket.thanks![]()
Might be hard to find one for the aircooler but I'd try calling Cometic and see what they can do for you. http://www.cometic.com/contactus.aspx
a honda fl-350r oddessy gasket will work I'm told I don't no this for a fact but thats what has been said
Trikes currently owned
E.T. trike 150H.P. and climbing Pure DRAG beast
85 250r project
thanks for the info.does anybody know for sure if the 350 gasket is 7 bolt and will work.thanks again guys.
check in the classifieds.Originally Posted by fla 2-stroke
I got a roll a quarters an making change !
If you search the boards I have found the 350 gasket fits but it has to be for the 329cc engine I believe it was and it does have the 7 studs. Or just buy 82300R's... I would if I had the money right now man!
ATCless at the moment...
1977 Firebird Formula
1997 Suzuki RM250
This may help.
http://3wheelerworldforums.com/showt...highlight=300r
Also you can do a search using my username and it should pop up a lot of 300R info. I did a pretty good write up during my build.
Lots O Trikes!!!!!
if its copper can you hone it out to fit?/ or file it
copper is soft
Cometic will have what you need here is part #base gasket BO297 The head gasket # is HO511. And that is for a honda atc 300 1981-84 77mm
82 300R tricked
02 blaster wife's
83 suzuki 250 dirt bike
82 300R drag monster
2007 suzuki hayabusa sweet street bike
looked those numbers up and all that comes up is the stock gasket set. 72mm. maybe i should pull the plug if they are that readily available.![]()
I just called Cometic about making me a .020in thick copper head gasket for my .010 over bore 85 Honda 250R and they quoted me about $28.00 shipped. Prety sweet for a custom head gasket if you ask me.
Current Bike:
1985 Honda 350X
Bikes owned:
1984 Honda 200X
1982 Honda 250R
1985 Honda 350X x3
1985 Honda 250R x2
1985 Honda 500X
Cometic will make/do just about anything, and their gaskets are very high quality![]()
