I have seen a few posts on people doing this, where can I get it done? I have seen prices from 50 dollars to 125-175 to 400 some dollars.
What are a few places that do this or even specialize in 350x heads?
1985 Honda 350x - Powroll 430 Kit & Lots more
1984 Yamaha YZ490 - All the 2-stroke goodies
Homemade "Trike"
Mickey Dunlaps Four Stroke Tech I think will still work on 350Xs. Someone told me a while back they talked to Curtis Sparks and he would too, just doesnt mess with 200x parts anymore. And then theres Tom Carlson of TC Racing. All three of those guys are oldschool trike gurus that were doing work when the 350Xs were brand new. Can't go wrong with either of the 3 IMO.
iv'e done a couple of 400ex heads along with a Triumph,Hyabusa,Kawi 1000,etc ..... just make sure who ever does the job doesn't mess it up !!!
"07" DR650 Suzuki Dual Sport
Would you be willing to do my 350x head? I always wanted to get into porting myself, once you understand it, it doesn't seem hard. Is there a good book or some other way to learn this?
Homemade "Trike"
Any bike shop that does custom engine work will do it. Just don't overdo it. A little goes a long way!
I just got off the phone with Tom Carlson (very helpful) and Curtis Sparks (doesnt do 350x anymore).
My end goal here is to have a Powroll 430 BB kit with all the goodies.
Tom told me I needed to do a few things in order.
-First is to build up the motor with a cam that matches it, correct piston, connecting rod, etc.
-Second is to get a proper exhaust for it. I suggested the DG or Cobra exhaust systems since that is all that seems to be available for this trike, and he told me those systems are garbage. They are stock replacements that are just an added silencer can with some tubing going from the motor to the can. Real racing exhaust systems are custom made, correct lengths, and may be significantly shorter than OEM.
-Third is to work on a new carburator, I suggested a 39mm Keihin FCR carb and he said that would be ideal for this setup.
-LAST is going to be your porting. The porting is what is going to compliment the mods you already have and be designed to help with the current riding you want to do (trail riding, sand riding, etc.) I chose trail riding and he said you want to focus on getting gobs of torque at quarter to half throttle. I told him some of the trails are flat stretches that can last for 2-3 miles and I would like to be able to really open it up and fly through those, would that be ok with all that "gobs of torque?" Definitely, he replied.
He told me a matched porting system like that would cost me around $500 dollars to do the head.
He also stated that you need to replace the CDI with a CDI box. The stock one is good to rev to about 8K, but after that it starts to retard the timing and you lose a lot of power. He still makes one that would correct this problem. I didnt get a price on this however.
It seems like 500 dollars is a little high, but he has gotten various awards including the Engine Builders award.
This will be good info for anyone else thinking about doing the 430 kit.
Homemade "Trike"
i have seen a thread on porting, it was called "what to cut" or something like that...i searched but came up with nothing
'85 ATC 250R
FMF Fatty & Power Core
Boyesen Rad Valve
38 PWK A/S
K&N w/PF (next purchase)
LSR +4 Axcaliber axle
LSR Duel row bearing carrier
DuraBlue Anti-fade (to be installed)
13/36 sprockets
'85 ATC 250R
Parts trike (maybe future build?)
CUT IT OUT !!!!! Polish the Exhaust and Bead Blast the Intake "after Porting"...
HOG IT !!!! TORQUE is what you Want !!! BIG Jetting !!
Definitely need a bigger carb, or else you won't be able to kick it over.
You will also have to remove the air box lid or the whole airbox, the 350x airbox is small and can't handle the cfm of the big carb and bore.
Let a pro do it, you get what you pay for. I paid $150 for my port job on the 350x, it's good, but, I am only running a slight overbore with a 10:1 compression and a midrange cam.
Will need valve springs also. hardened rockers. will have to shim the springs also. hows the cam bearing journals on your head?
i'll tell you what .............. send it to me ..................
i'll port it...you ride it "with the stock carb." and we or ....... "they" will see who's the Pro !! PM ME............... 2 WEEK Turn Around .........
If you read my sig it says I have already removed the air box lid. The Powroll kit that I want comes with better valve springs, and hard face rockers are a must. I'm sure my cam journals are worn from normal use, but probably still with in speck (which will be checked before I install a cam).Originally Posted by phil53
Where did you go to get a port job done for 150 dollars?
Homemade "Trike"
I may take you up on this offer, and I'm sure it will work with the stock carb, but I really want something larger (39mm at least) to complement the 430 kit with a high lift/duration cam.Originally Posted by Yamahondaman
Jake
Homemade "Trike"
Tell me where you want the power and send it to me. Ive done a bunch of them and ask anyone thats seen my X go, SHES A RUNNER.
I'll do the Fly Wheel and NOS can do the Head !!! it'll RUN !!!![]()
Sure, I would like it for trail riding, I think a port job going for midrange to high power would be great. The cam I want is .360 Lift and 284 Duration, its the Web Cam just below the Race One. I think the stroker kit will give me plenty of low end torque I desire, and this port job will match the cam nicely. Think it will be ok?Originally Posted by NOS_350X
Do you mean lighten the flywheel? How will that run in the trails? Won't I loose almost all of my torque?Originally Posted by Yamahondaman
Homemade "Trike"
