I am planning on getting a new Durablue axle and I would like to get all new hubs.
I can't seem to locate a anti-fade brake hub. So now my question is what will interchange and line up? trx 250r,250x,300ex,400ex,or 450r?
Thanks
Thanks
84 Z28 Camaro
94 Caprice 9C1
02 2500HD Silverado 4x4 ext cab
84 atc70
85 250R
87 Big Red
90 VTR 250
it won't work, you need a 350x one. 85-89 250r ones will fit, but the spacing is off. If you machine 3.5mm off a 250r hub(must be stock), you can put the 250r/350x axle bolt in, also put a 85-89 250r rotor, and 86-89 250r caliper holder you can put a 86-89 250r rear caliper on it. I would look for a 350x brake hub and disc, unless you want much better brakes.
I don't know for sure, but I think a 250x/300ex hub will work too.
