Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: 1985 350x Weird problem
    Nov 2006
    aurora, IN
    18
    Here is the same problem I'm having with my 350x.............
    http://www.3wheelerworldforums.com/s...ht=350x+stator
    Nov 2006
    aurora, IN
    18
    I hate to bring this to the top, but I really need some help.
    Apr 2006
    Crestview, Florida
    2,429
    have you checked the cam timing and valve adjustment ? looked the wiring over for damaged spots?
    Nov 2006
    aurora, IN
    18
    Yeah the timing and valves are fine, its for sure an electrical problem. I've checked every connection, and wire everything looks great. I've pretty much narrowed it down to the stator or the cdi. I've read a lot of posts on the net with people having similar problems with the stator, starts losing power on top end, then usally quits working completely. I'm just looking for someone who has had this problem, if it was anything similar. I don't have the book to check the stator, plus I've read that the test can be somewhat iffy anyway. The link in the above post is the exact problem im having.
    Nov 2005
    New Jersey
    659
    The manual I think says you can check that CDI with a ohm meter right?
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    Nov 2006
    aurora, IN
    18
    Ok thanks for all the help fellas, also the guys post I posted above emailed me, and said that his was a loose jet. I did put a inline filter in, so i'll take that out, and i'm also ordering a carb rebuild kit, and the left gasket tomorrow. I pray that takes care of the problem, I don't want to miss out on the first good snow riddin. I keep you guys updated.
