does the head pipe off any other bike work on the 350X ( bolt up or with mods )
main question is will they bolt up to the head, i can make the rest fit larry
RIDE SIDEWAYS![]()
got another addiction
Honda's
86 ATC 350X
T/F Survivor 06 / 07
SANDPUPPI Survivor 07 / 08
I am told a 400ex is a close fit, but requires some cutting and welding
I'm almost positive that they will bolt right up to the 350x head. The only thing that has to be modded is the end of the header where the silencer hooks up.
thanks guys
RIDE SIDEWAYS![]()
Honda's
86 ATC 350X
cutting and welding are required for a 400ex pipe same thing with the xr400 pipe, i havent tryed the bigger xr pipes yet. The cutting and welding isnt that bad, its that its such a tight fit you have to remove the cam chain tensioner to get the headpipe on. With 1 well placed cut and weld on the headpipe of a 400ex you can use the full system rather easly.
