Results 1 to 9 of 9
Thread: 2 stroke porting tips
    Oct 2006
    Bimringham, AL USA
    7
    Hello all.
    I am new to the site, just would like some details on porting a CR500 motor I am putting into my ATC250R. I am good with a rotary tool and have all the tools to do the job. What I need is figure out the best porting for what I am looking for. I don't want to go beyond reliability. Basically I just want to smooth things out and radius what needs to be radiused. I am sure that will free up some power.
    I will be getting deep with the swap here in the next few weeks. I bought a spare frame and it will start when it gets here.
    Bryan
    gravelord is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Hillsborough,NJ
    300
    from what im told porting goes way beyond what you can do with just the tools and how much time you have on your hands... you dont have much of a option with doing it your self unless you want to hurt reliability and ruin your cylinder maybe perminantly, best to just send it out some where. most i ever did was bore out the exhaust port to a ALT50 / LT50 engine and clean it up, just my opinion though. not saying it cant be done! just saying i doubt itd be as good as sending it some where and paying 200- 300 bucks
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I've got a ton of books on 2 stroke engine tuning. Collecting more all the time. The best one so far IMO is Gordon Jenning's 2 stroke tuners handbook. Its hard to find, but it has all the info your looking for.
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    Nov 2006
    Chicago
    270
    Jeening's book is also available in PDF format. Found this link earlier this year and it's still live:
    http://edj.net/2stroke/jennings/
    Jan 2004
    NJ
    1,646
    After porting the head should be flow tested.
    3 CR500R's and counting. Do I really need 4???
    Do I really need 9 Tigers?
    Laegers ATC500R
    DO NOT send any thing to whats his face (dirt-face/crasher) here on the board. What a scum bag. He screwed (stole) money from me and screwed me on my ME360 and Hondaline 300R engine rebuilds.
    Live Oak, FL
    15,069
    What part of the head are you going to flow test on a CR500 or a 250R? The water jackets?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    Cleaning up the ports will give you a piece of mind and thats all,,, you will not see any increase in power at all,,, its all in port timing , compression, and tuning,,, http://www.macdizzy.com/cyl_primer.htm is a great place to read ,,,
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    as someone that ports its not as much rocket science as people like to make you think.
    I port polaris jugs whihc are a 250r rip off in configuration shape etc. if you follow the correct steps you should have a long running engine even if you half take care of it.
    chamfer the ports correctly about 30degrees. a general rule is not to excede 60% of bore width on your exhaust or the rings may not return correctly. and if there are boost ports get them till you can atleast stick your index finger in them assuming there on the intake itself, look to see if the sleave matches the jug itself and match them up. the real tricky parts are the transfers and the openings but without touching them you won;t be doing too much.
    just go easy and remeber you can always open it up again, Ive ridden a cr500 and can;t say you would truly want much more then it already has. you can also stack base gaskets for some more height.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
