i have had the same issue for almost two years now. i have rebuilt the carfb several times and I can still not figure this out. im subscribing hoping you figure something out, I think its a cam chain issue as I have some tapping. ive gone up and down on jets drastically no air box, air box etc. plug actually tends to look ok, ive also changed heat ranges several times.
hopefully this will give you some idea's/ help.
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
