I recently purchased a '85 Tri-Z with a 5 speed. Question: what is the difference between the '85 and '86 in terms of engine? Can I convert the '85 engine into a 6 speed trans from a '86 motor? Will it fit or when they made changes in '86, did they change the whole engine?
If that can't work, is there another 6 speed engine out there to where it's gears would fit into the '85? I want to keep the motor but upgrade the trans if possible. Thanks for your time.
Thanks for the reply.
