Well went for my first "full ride" on the Z today, naticed while i was riding, three was a slight knocking sound, and the clutch was a little whacky slipping it high speeds, and it wasnt like a wind out slip it felt more like three was teeth missing off a gear inside. and when i got home i drained the bottom end, and all this crappy oil and then water, came out. Also i took the stator cover off and there was water in that aswell. i pressure tested the bottom end and there was no leaking into the stator cover so it must be seperate. What I was wonderin was..how did the water get in the bottom end? I did go through a big huge puddle that covered the engine. would it have been sucked through the trans breather tube? the engine is very fresh and the gaskets are good. Except i think the stator cover gasket might be crap, because it was wet inside. Any suggestions? I dont want to ruin this bike, its the nicest one i have!
