OK Tri-Z folks. My 86 Z is having issues with the clutch. New cable on it and I have taken apart becasue I thought that the bar the cable hooks to had come up and the pushrod was under it. Ball is in place, rod is straight, basket is right. Put everything back together and it will not disengage quite enough-even if I adjust the cable out at the bars. I have adjusted as the manual says, yet it still will not roll freely with the clutch in and in gear. Had fuel pump issues so I had to pull start the other day and the cluth would disengage at faster speeds only. Could the ball be worn enough to cause this? Any help would be greatly appreciated! Also, where can I get a fuel pump rebuild kit? Thanks
