I don't get it, the service manual calls for 47ft lbs on this nut but if I make it over finger tight it binds on the basket and locks the two together. I've got the thick washer/shim in between the basket and the hub, washer and lock washer under the nut on the outside of the shaft. I'm running a Hinson basket with a brand new 89 clutch hub. It looks like the hub is extended out past the end of the shaft, and I'm thinking it should be flat/flush with it. If thats the case then I need to make a thinner washer that goes in between the hub and basket or I need to cut a little off of the hub where the shaft comes through.
I'll try and get a picture of what I'm talking about.
it moved back over to the right some and centered itself up. It rolls good and free after its all bolted up now.
