Results 1 to 15 of 18
Thread: What is it that fails when HONDA kickstarts slip??
    Do the teeth merely get rounded or is there something else that happens. This is in a 250SX but probably similar to all the Hondas.
    Ashland City, TN
    2,576
    I dunno, but this TLR200 that I rode not too long ago when you went to kick it, it would occasional just slip right down and not turn over. I imagine it's something internaly with the kicker gears??
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Howdy's Avatar
    Celina, Ohio
    10,079
    On the 250sx & 250es's the problem is the one way clutch. I bet it also make a whirling noise when it's turned off also. That is a tell tail sign of a bad one way clutch ( Honda calls it a clutch sprag? )
    It's in behind the centrifical clutch. It is a faily easy fix but it's not too cheap. The clutch sprag ( one way clutch ) cost $60-$80 ( I can't remember the exact cost ).
    Howdy
    Feb 2003
    California
    623
    x
    On my 200x it slips if you don't use the kicker right. It will make a nasty, crack sound that doesn't sound good. I don't know what do about it
    Ashland City, TN
    2,576
    60-80 bucks for some little clutch? That's ridiculous!!
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Apr 2002
    s.w. michigan
    6,498
    sx kick starter gears
    Dirtcrasher, like howdy said,,, fairly easy to work on. i have never been into them gears on my bigred but my book say's there the same assembly/components. there is sevral pages related to the kick starter.
    do you want me to run copys out of my book and mail it to you ?
    oh yeah,,, the better news, don't appear you hafta break the cases in half like i am gonna hafta do on my possesed lil 200x to get to a worn kicker gear.
    john
    Thanks John I have the manual I just need to get it apart!
    Howdy, Now that were on the subject. I've seen one way clutches in machinery forcing drive in one direction only, but how does it relate to a kickstarter in an SX?? Whats it do??
    Wonder how many people condemn the gears before realizing it's that!! oops
    Thanks guys
    Howdy's Avatar
    Celina, Ohio
    10,079
    Here is the short of it:
    The kick starter actuates the kicker gears that spins the centrifical clutch. The one-way clutch transfers the centrifical clutch spinning to the crank shaft. When the crank shaft spins you get it running ( normally ).
    I forgot to mention this earlier: The one-way clutch is actually dual purpose. It also keeps the motor from spinning or kicking backwards when the motor is shut off. If it doesn't stop the backward spin the starter gears will get damaged ( if the motor kicks backwards ).
    This is the most common cause of starter failers I have found on the 250cc motors. Anyone that has seen the starter & gears chewed up knows what I am talking about.
    When you figure the cost to replace the electric starter and gears in machine then the one-way clutch is really cheap.
    Minnesota
    784
    on a 200x its most likly the ratched gears inbetween the cases. I'm not sure what causes it, possible people kicking it over fast like a dirt bike? I always kick it slowly, then bring the lever 1/2 way up, almost parralell to the ground then kick it.
    ATCkrazy is offline At The Back Of The Pack Arm chair racerFirst time rider
    re.
    my 250SX does the same thing, it slips unless it's warmed up, im sure it's the sprag, new one is $94.99 at my honda shop, ouch.
    86 ATC-250SX, 83 ATC-200S, 1980 XR250R, 1980 moto-ski mirage 377 special, 83 Ski-Doo Citation SS 377, 91 Ski-Doo safari 447, 92 FORD F-250 HD, 4x4, 351W shes a work horse.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by hrc200x
    The 250sx & 250es kick starter set ups are completely different than any of the 200x's, 250r's, or 350x's. Comparing the 2 is like comparing a vacum cleaner to a TV.
    Howdy
    Aug 2002
    332
    Now wait a minute...my TV and vacuum are both panasonic!
    j/k :-D
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    Minnesota
    784
    I brought a 200x into this post because wanta250r asked what he could do about it to make it not slip on his 200x.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: x
    hrc200x. I missed that one. Sorry
    Quote Originally Posted by wanta250r
    The Early model 200x's had a problem with the kick starters. Honda's cheap fix on that was adding a extra spring on the kick starter. How ever to add the spring you needed to split the cases. I just so happen to have a copy of the service bulletin Honda sent to the dealers at the time. I never thought about it but It is a must to add to the site. I will see if I can bring them home with me from the shop today.
    Howdy
    Feb 2003
    California
    623
    x
    Yah, mine is an 83, thanks. )
