Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: What is it that fails when HONDA kickstarts slip??
    Roanoke, VA
    4,038
    Mine did that too and I found out that if you push the lever in a little with your foot while kicking it...it would work great and not slip. At least it worked for me.
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Apr 2002
    s.w. michigan
    6,498
    mine too !
    ATC crazy, mine is the same way ! i stand up and get a firm compression stroke ready to go and like you said,,, just kinda kick inboard or towards the skid plate and it catchs 9 times out of ten.
    untill i discovered that i thought i was gonna haft to split the case again.
    still will probly next fall or winter if i have it that long.
    i am a thinking that a thrust washer had been left out oor worn out if not the teeth on the kicker shaft (inside)
    john
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    My SX used to do that now and again. I would hurt sometimes if you you were giving it a good kick when it slipped. But since my output shaft shattered and I got a new bottom end the new bottom end hasn't slipped on me yet. My friend's SX on the other hand slips all the time.
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
