Thread: 200x front tire or tube repair?
    Apr 2005
    Blue Ridge Mtns NC
    59
    Question 200x front tire or tube repair?
    Hi all, I have an 85 200X which still has the H-trac Pro Vector tire in very good shape, However I suppose I have some dry rot starting on the side walls and it leaks down after sitting for about 4-5 days. I was thinking about putting a tube in the tire to prolong the tire and to keep it original.
    Anyone have any thoughts about tubes, or should I let the old H-trac die and replace it with aftermarket tires?
    Cody's Avatar
    Cody is offline Just Too Addicted Arm chair racerJust too addicted
    Feb 2005
    FLORIDA
    731
    Thats what I would do.
    1985 Yamaha 200E Shaft - New Toy / Project
    1983 Yamaha YT175 - Kinda retired?
    Howdy's Avatar
    Celina, Ohio
    10,079
    I have done it both ways. Minor weather cracking isn't bad, but if it's cracked a bunch to very badly, then it's replacement time.
    Howdy
    illinois
    743
    fill the weather cracks with rubber cement or super glue- sounds crazy but its chemicaly bonding and works great -
    espescialy if you have a gouge or slice in your good tire-
    while mine was aired up - it was like a inch long and deep!
    i used some new good krazy glue- no problems just apply it a couple times with the air out let dry and air it up and youll see
    hey you asked - lol
    Apr 2006
    Crestview, Florida
    2,429
    glue wont last . it doesnt expand or flex the same as rubber, not to mention it isnt safe.a high speed blow out isnt fun. just green slime it or get a tube.
