Results 1 to 8 of 8
Thread: 85 suzuki jr50
    bigb9582's Avatar
    bigb9582 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2005
    pa
    167
    85 suzuki jr50
    hey guys i got a question. i working on a friends suzuki jr50 that has been sitting for about 15 years. its a two stroke. i was wondering if anyone knows how oil the tranny holds. theres no check window on the case and no dipstick on the filler hole plug. sometime ago thier basement must have flooded because the 15 year old oil was a little water down.
    surprizing thing is it still runs when i put a little mixed gas down the carb hole. carb is trashed , corroded and cracked in places, looks like someone jb welded the crapp out of it, so its pretty much none fixable. so a new one is one the way, i hope to have it running this weekend once i find out how much oil it holds.
    85 atc250sx
    86 lt230s
    VABCH350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    Whidbey Island, WA
    322
    Look on the engine case, the oil capacity should be stamped on it. There should also be a check bolt on the side of the engine.
    Good times,
    Paul
    86 Honda ATC350X
    86 Honda TRX70
    02 Honda TRX400EX
    03 Kawasaki KFX80
    82 Honda CB900F
    bigb9582's Avatar
    Feb 2005
    pa
    167
    ill have to look again but i do remember that it says 366 or something like that on the case. the only bolt i remember seeing is up by the kick starter, all other bolts were for the side case. but like i said ill have to look again.
    85 atc250sx
    86 lt230s
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    My neighbor has one of those!!!! His kid rides it daily. I'll holler at him as far as the capacities, and I'll post the results. Gimme a day or two.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    bigb9582's Avatar
    Feb 2005
    pa
    167
    cool thanx.
    85 atc250sx
    86 lt230s
    Central FL USA
    1,174
    It says 450 ml on the side of the case. My buddy says he'll drain the oil, then, put just a little under half a qt. of straight 30w oil in there when he changes it (every 6-8 mos.). He has been doing so with great results since 1990. Bike runs great and is a daily rider.
    Hope that helps
    bigb9582's Avatar
    Feb 2005
    pa
    167
    cool thanx. i guess ill go out and get it running today.
    85 atc250sx
    86 lt230s
    Dec 2006
    Missouri
    8
    Sent you a PM about the JR50
