Originally Posted by
p26575r16
I have an '86 350x that I will be remodding soon. My goal is to keep it looking as original as I can but making it faster and more comforatable to ride. So far I have a new 12.5 to 1 piston and cylinder assembly, a used head assembly (I will be porting this one to accommadate the new higher compression), and a used 1986 frame (mine was cracked and very poorly repaired by the original owner). I will also be getting a used swingarm and extending it 2 inches, lowering the trike at least an inch, changing the carb, adding 2 1/2" wheel spacers or an extended axle, and getting the seat recovered by moshman. I have also been debating on whether or not to go with a 10.5 to 1 piston instead of the 12.5 to 1. My questions are: What type of cam should I use (I have been looking at both cams offered by powroll), What type of paint should I use on the frame (I am not going to powdercoat the frame), and what type of carb should I use? Thanks alot for the help.
