I have a 1986 Honda 200x and i just bough a cobra pipe but i dont know how to install it. I want to know the Jet size and what i do with the air filter And wich type of filter i put in . Detailed answer plz![]()
Tri-z 1985 resto project
Arctic Cat Prowler 440 90 --- raised handlebar -Homade cherry bomb exhaust ! - Custom Tuck tape seat cover- Sled Mod by SREDNECK
Kawasaki Z1000 04 -- Offmarket front disk - Yoshimura tr-s carbon slip-on- Bmc air filter- Power commander 3- Airbox Mod- Inc flasher tail light-Action pro steering damper-
IM FRENCH so sorry about all thoses grammar mistake o.O
Jetting will vary due to altitude and engine mods. I bought a few different sized jets when I installed the cobra pipe on my 350x. I then changed the jets until I found one that worked the best. At 7000 feet the stock jetting worked best (It had a bigger jet in it to begin with due to being from St. Louis at 300 feet). As far as the air filter goes I have a Uni filter in mine. I would like to get a k&n, but even the stock air filter will work.
your prob gonna need to go up a size for the main jet with the filter.i wouldnt go with a k&n,they let dirt in and could wreck *Edited**Edited* motor.uni filters are fine
86 250 sx-my baby
86 250 es-needs little work
83 atc 110-frame up resto
82 nighthawk 750(for sale)
I did nothing to my x when i installed the cobra. Only problem is that the header needed grinded down to fit in the muffler.
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
the best way i would say is going to be install the pipe. Make sure whatever filter you have is good and clean. Airbox lid is optional. Install a fresh plug and take it down the road. Take the plug out and see what color it is. If its white you are lean and need to get a larger main (you can try raising the needle but a main is the best way). If you have to go up say 3 sizes on you main I myself would step up one size on the pilot jet.
1985 Honda ATC 350X
2003 Yamaha Banshee
2003 Polaris Sportsman 500
There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
Anyone who doesn't rejet is wasting their money on a pipe...
My 200X with Cobra got it's lid removed permanently and I drilled out the main to a drill size or 2 just below a 350X. Motor is stock otherwise and NOT running too rich. 3 sizes up at least was a minimum in my case.
Buying jets is great, but you can spend 40$ on jets real quick. I prefer to buy junk spare carbs and use number drill sizes until that "bogging" goes away. Usually takes about 3 shots removal and installation until you get it right...
heres my 200x wth a cobra. drilled out the jet to 4 size's up before it worked right
uni filter and all stock except clutches. all i can say is![]()
Roadrash on the butt is'nt cool!
If you saw my stock exaust you would see why i needed a new one. Mine didnt need rejetted because it already had a rigged up ker-ker on there.
I have a 350x supertrapp on my 86 200x, I had a cobra on it, I took off the cobra silencer, put the supertrapp on, cut the header back and done. I found that the optional spark arrester made my cobra system alot less annoying to ride, and improved the power some. Also ALOT quieter, the corba without the spark arrester was so loud, it was very hard to ride, it hurt your ears. I had to wear ear plugs for it!!!!!!
here are some pics of it. Its not a current pic, but the exhaust is still the same.
http://www.pictureposter.allbrand.nu...app+1.JPG.html
http://www.pictureposter.allbrand.nu...app+2.JPG.html
http://www.pictureposter.allbrand.nu...trapp.JPG.html
Thx alot ill put a 3size up for my main jet and ill let filtor stock. thx alot and if it doesnt work ill try to get a size up on pilot jetthx alo alot
Hey did the three sizes up help. Just curious im looking to bump mine up a couple sizes.
ive got a cobra on my 200x auto and it seems to be rich as hell lol and the carb is a stock x carb on the 200 s motor with a uni filter
hey deathman where did you get those foot pegs?
BIKES CURRENTLY IN MY GARAGE
1990 XR80R
1983 CR60R
1986 250SX
1985 250R
those are 86/87 trx250r roll design pegs
