Results 1 to 3 of 3
Thread: Motor Rebuild?
    Motor Rebuild?
    I am gonna rebuild a 200s motor i got. I have a Gasket set. Wiseco 12;1 piston, carb rebuild, anyway. Can i just put in the 12:1 just like a stock piston or does it have to be clearenced and then be sure the valves wont hit the piston??? How do i do it? Are they a pain or just bolt in...??
    Guest
    on my 200x
    On my 200x, i had a 10.25/1 piston in it, and had to do nothing but hone out the cylinder and put the rings in, i wouldnt think the 200s or any other would have to be "clearanced" for the piston, although i may be wrong, only thing you could do is ask a dealer, or put it in the cylinder, push the cylinder down, put the valve component on and see if it hits. thats my only guesses. Hope this helps.
    Brad
    May 2002
    Southeastern Wisconsin
    3,658
    Anytime you stick a 12:1 in a machine you should check it. If your installing a cam too I would check it with out question.
