Thread: 38mm air stryker carb IDLE????
    gravelord is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Hillsborough,NJ
    300
    i cant seem to get my 250r to idle..
    climate is around 20-30 degrees, 178 main jet, stock 86 needle clip set to the middle, v-force 3 reeds, ported cylinder, milled head, cr head gasket, no air box lid, fmf pipe. no matter how much i screw in the idle screw it wont idle. inside of carb is nice and clean, fresh bore in the clyinder, bike runs strong.
    just figured id tell you what i could, my friend has 250r's with the same carb and said he cant get his to idle either. when i first got it my bike would idle with the carb, i cleaned the carb out because i got it used, and the float kept sticking and there was lots of crud in there, ever since then it ran better but wouldnt idle.
    Also, does any one have a picture of what a 250r's spark plug should look like jetted PERFECTLY ?? ok thanks guys.
    Pete is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2003
    Lino Lakes, MN
    229
    why do you have the stock 86 needle in the carb? What size PILOT jet do you have in the carb?
    Jackson MI
    1,688
    Is the idle screw all the way In (the one that pushes the slide up) & It still wont Idle? Be carful some of the idle screws are plastic, I watch the spring on the Idle screw & stop If It's all the way compressed. If that screw Is all the way In & you can't make It Idle with the air screw, then your pilot jet Is probly to big.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jul 2006
    Hillsborough,NJ
    300
    i was leaning out the mixture by putting the 86 needle in.
    i have the main jet that came with the carb
    Ontario, Canada
    457
    in the sticky Damitt! wrote up a thing on jetting, theres a link in there with pictures....i bought my 38mm A/S q/v and it came with a 170 main a 50 pilot and a ddj needle, but i haven't run it yet
    '85 ATC 250R
    FMF Fatty & Power Core
    Boyesen Rad Valve
    38 PWK A/S
    K&N w/PF (next purchase)
    LSR +4 Axcaliber axle
    LSR Duel row bearing carrier
    DuraBlue Anti-fade (to be installed)
    13/36 sprockets
    '85 ATC 250R
    Parts trike (maybe future build?)
    Newfoundland
    5,280
    What about your airscrew? If its screwed all the way in it won't idle. Like was said, did a post on this exact topic a long time back.
    Did you do all those mods all at once?
